Page 1 of 14
Posted: Tue Dec 17, 2019 7:43 am
It is typical situation when people have MyKey enabled and have no Admin key that would allow to clear MyKey feature. Previously, our support answered that there are 2 ways to do it with FORScan:
1. Reprogram PATS - erase all known keys and program 2 new ones. This removes MyKey completely, but it is quite "heavy" way: it requires 2 working different good quality keys and PATS programming functions (in FORScan it is available not for all models).
2. Disable MyKey options in IPC and other modules if available. This removes chimes and warnings, but not MyKey itself. Some limits, like speed limit, may remain active after this procedure.
You now have MyKey removed.
Note: this was tested on cars with gasoline engine, not tested on diesel engines.
Please leave your feedback on this method.
Posted: Tue Dec 17, 2019 6:33 pm
by Andyfocus
2017 ford focus - just says immobilser active check blah blah ,then my key active ,
so no dont work on 2017's.
tested with just turning engine off key in ignition acc position then on , engine off with key in ignition all off , key out of ignition
on number 5 in the list.
I think someones winding you up or they used the master key by mistake and not the my-key - get in touch with them and get them to send you a video of it.....
if they use remote start then that is why it worked as it run in admin mode with remote start so can only be done with remote start on a my-key.
Posted: Wed Dec 18, 2019 8:41 am
Did you follow the instruction precisely? Was KOER test successfully ran and completed?
This was successfully tested on Mustang 2.3 2016 with keyless entry and start.
Posted: Wed Dec 18, 2019 2:49 pm
by Andyfocus
yes followed the instructions ,
the reason it worked for them is the car was remote start , everyone knows that with remote start you can do this already , with no need to do anything but to use the remote start to start the car and erase the my-keys , you dont need to do anything else (no running of any diagnostics required )
Posted: Wed Dec 18, 2019 4:15 pm
by omar302
I just tried it on my 2016 Edge Sport and it works. Followed the steps completely. To get the keyfob outside I just opened the window and put my hand with the keyfob outside the window.
Posted: Sat Dec 21, 2019 9:55 pm
by Andyfocus
ok been out side again sat in the car for an hour trying different things including just using a keyblade for the key on only part , still does exactly the same no go , immobiler active see handbook ,my-key active blah blah etc etc.
so no dont work
Posted: Mon Dec 23, 2019 5:39 am
by xzine311
I also can't get mine to work, I have a 2013 Ford Fusion, I have the OBDII reader and Forscan, I DONT have a keyless start, I have a blade key and I have tried just about everything. I don't have the PATs option on forscan, I only have 1 key and the other key which the dealership said they didn't have when we got the car is set to an admin key. I am just sick of it and don't want to spend $300 on a new key that they say has to be totally reprogrammed.
I even tried taking my key apart starting the car without the fob part, with just the blade and trying it the keyless way by walking away from the car, and no go, I tried tin foil as well. The car just tells me no key detected and defaults to MyKey state
Posted: Mon Dec 23, 2019 9:49 am
by Andyfocus
xzine311 wrote: Mon Dec 23, 2019 5:39 am I also can't get mine to work, I have a 2013 Ford Fusion, I have the OBDII reader and Forscan, I DONT have a keyless start, I have a blade key and I have tried just about everything. I don't have the PATs option on forscan, I only have 1 key and the other key which the dealership said they didn't have when we got the car is set to an admin key. I am just sick of it and don't want to spend $300 on a new key that they say has to be totally reprogrammed.
you should have the pats option in a 2013 model.....
Posted: Mon Dec 23, 2019 12:59 pm
by xzine311
I was thinking the same thing but I can’t see it any where, it’s not under any of the service tools and I even updated the drivers for the reader.
Posted: Fri Jan 03, 2020 9:47 pm
by bnet
FORScan wrote: Tue Dec 17, 2019 7:43 am ...
Ford F-150 2015 2.7 - Работает, спасибо!
