Forscan 2.4.1 - adaptor compatability
andyh1108
Vehicle: Edge 2.0 TDCi 210
Post by andyh1108 »
Hi Guys
Thank you very much for your hard work in getting version 2.4.1 out, really looking forward to updating my modules. Quick question, release notes seem to suggest that module update will only work with OBDLink EX and MX+, is this correct as I have J2534 Ford VCM II which worked fine with later beta versions of 2.4.0
Andy
xrdude
Vehicle: Focus ST MK3.5
Re: Forscan 2.4.1 - adaptor compatability
Post by xrdude »
from the release notes..
4. Adapters
This version only allows wired adapters to be used with MFU. For J2534 PassThru adapters there are no other limitations. ELM327 adapters must have increased baud rate (>38400) and minimum response time <20ms. It is not recommended to use any china ELM327 for MFU. It is recommended to use either J2534 PassThru or OBDLink EX (see note below).
So your adaptor should be no problem.
andyh1108
Post by andyh1108 »
Thanks, missed that! <DOH>
Mondimk3
Vehicle: Mk3, 2000cm tddi/115km/2002
Post by Mondimk3 »
Witam używam adaptera icar II wifi czy będzie z nim problem??
Vehicle: *** Ford ***
Post by f-wolf »
Mondimk3 wrote: Fri Oct 16, 2020 8:26 pm Witam używam adaptera icar II wifi czy będzie z nim problem??
WHAT are you talking about ???
:roll:
dany101
Vehicle: Ford Focus 2015
Post by dany101 »
Polish traduction: Hello, I am using the icar II wifi adapter, will there be a problem with it ??
Post by tractmec »
dany101 wrote: Fri Oct 30, 2020 11:29 pm Polish traduction: Hello, I am using the icar II wifi adapter, will there be a problem with it ??
The first sentence in the following Quote should answer your question!
"This version only allows wired adapters to be used with MFU. For J2534 PassThru adapters there are no other limitations. ELM327 adapters must have increased baud rate (>38400) and minimum response time <20ms. It is not recommended to use any china ELM327 for MFU. It is recommended to use either J2534 PassThru or OBDLink EX "
