U3003 and U0415
Posted: Sat Jul 18, 2015 8:23 pm
Hi!
I cannot get rid of the following two fault codes:
===ABS DTC U3003:17-60===
Code: U3003 - Battery Voltage
Additional Fault Symptom:
- Circuit Voltage Above Threshold
Status:
- Test not complete
Module: Anti-Lock Brake / Traction Control Module
Freeze Frame :
-GLOBTIM: 2359650 sec - Global real time
-TOTDIST: 72020.0 km - Total Distance
-MAINECUV: 14.75 Volt - Main ECU voltage supply
-OUTTMP: 23 °C - External Temperature From Sensor
===END ABS DTC===
===RCM DTC U0415:00-2E===
Code: U0415 - Invalid Data Received From ABS Control Module
Status:
Module: Restraint Control Module
===END RCM DTC===
I noticed from another threat that sometimes adapters can cause incorrect fault codes. Could that be the root cause as well? Any other ideas how to start resolving these from here?
Thanks!
Status:
- Test not complete
Freeze Frame :
===END ABS DTC===
Status:
===END RCM DTC===
Thanks!
