Offline configuration of PID measurements
Posted: Mon Aug 31, 2015 6:45 pm
by peterimnetz
Hi there, thank you for this great tool. What I miss a little bit is an offline configuration for measurements (e.g. on base of saved vehicle configurations). Do you plan to update Forscan with such a function in the future?
Re: Offline configuration of PID measurements
Posted: Tue Sep 01, 2015 9:02 am
You can save data stream (parameters reading) to a FSL file, and can open it later even in offline mode. You can also export you stream to a csv file and analyze it in a 3rd party tool. Or you mean some other offline work?
Posted: Sun Sep 06, 2015 6:52 pm
by peterimnetz
Hi, I mean not offline opening the measurements (which works quite fine) but to do an offline configuration of measured signals.
Posted: Mon Sep 07, 2015 4:10 am
It works so because set of parameters available for reading is vehicle dependent. So FORScan cannot determine what PIDs to offer until the moment vehicle is connected. The problem will be solved when we implement a function of manual vehicle selection (when desired vehicle is selected from a list and not detected in an automated way during the connection procedure like now). This function was added to the development plan some time ago
