Ford supported PID
Posted: Fri Nov 06, 2015 1:24 pm
I've been reading quite a bit one here but this is my first post.
Found the forum by googling an iphone app that looked exactly like what I need. I'll admit I'm rather new to this (iphone- wifi obd live monitoring) and have always used handheld scanners but I need more functionality as I'm tracing a false over heat problem on a 2006 ford f150 (mine) and I need to real time monitor several engine parameters including CHT (cylinder head temperature).
I see the virtual CHT gauge on the forscan app BUT- when researching OBD adapters, no one can seem to tell me if that (CHT) function is supported. It's not specifically listed as supported on any of the clone Elm327 command sets and emails asking have not answered my question. When I looked into the real deal obdlink MX- it doesn't seem listed either...at least not in the standard command set listings but may be in the Ford enhancement?
Any quidance wold be appreciated.. even a recommendation on an adapter would be helpful since I've read most of the posts regarding adapters and it seems newer offerings are less likely to work- even though they may "look" like adapter which have worked in the past. I'm leaning towards either a legit oblink (not sure which one I should get- if SX would work that would be great) OR if one of the available clones could be used. BTW - I also have a laptop so using the iphone isn't required... it just seemed rather convenient.
thanks in advance.
John
thanks in advance.
John
