The service procedure has been interrupted. (SOLVED) PATS
Posted: Mon Apr 05, 2021 8:24 pm
by GermanTourneo
Hello everyone, I have a ford tourneo 1.8 tddi 2006 75cv, I am initializing the fip module
I follow the steps well, and then when it tells me that it needs 10 more minutes to erase the immobilizer remotely, it always gets the error
"The service procedure has been interrupted"
I am doing something wrong? I have tried to delete all the keys (there are two) and to add them, and it goes well, but then when reinitializing the FIP, I always get that error. Does anyone know something ? If you need more information, I can provide it, greeting.
Re: The service procedure has been interrupted. PATS
Posted: Tue Apr 06, 2021 1:55 am
by Ripped
Are you using the OBDLink EX FORScan OBD Adapter?
Posted: Tue Apr 06, 2021 9:18 am
by GermanTourneo
No, I am using the ELM327 ford, this same
that may be the problem?
Posted: Tue Apr 06, 2021 9:36 am
by MoJo88
That's likely to be your problem then. Buy OBDLink EX.
Posted: Tue Apr 06, 2021 9:53 am
by GermanTourneo
This do I need to buy?
i didn't know him thanks a lot !
https://es.aliexpress.com/item/40009955 ... hweb201603_
Posted: Sun Apr 18, 2021 8:11 pm
by GermanTourneo
Good ! I am about to buy this obdlink EX on aliexpress.
Am I buying it from the correct site?
Is it valid to adapt the VP30 pump in the ford Tourneo 1.8 TDDI 75 hp year 2006?
I think I have a J1850 protocol, and I have a Visteon DPC 808 ecu.
Will it be used to adapt the scrapping pump?
Posted: Fri May 07, 2021 8:06 pm
by GermanTourneo
Today I received the ibdlink EX cable and I have not been successful. I have the same error again. The service procedure has been interrupted.
I am using windows xp, and forscan connects correctly. The obdlink EX drivers were installed successfully. That could be happening ?
Posted: Sat May 08, 2021 10:25 pm
by MoJo88
I didn't know that OBDLink sold on aliexpress. Are you sure it's not a clone?
You should purchase OBDLink from OBDLink.
Posted: Sun May 09, 2021 12:02 am
by GermanTourneo
Yes, I bought it from the obdlink store. Is this correct?
Could the problem be that the vp30 pump is blocked?
Re: The service procedure has been interrupted. (SOLVED) PATS
Posted: Tue May 11, 2021 4:53 pm
by GermanTourneo
The problem is solved! the problem was that the pump module did not have 12v power. And the programming of the country never started.
But now I have another problem
. Once the adaptation is complete, it asks me to turn off the ignition, but it asks me again and again. What can be ?
