Page 1 of 2
Remote start for Ecosport
Posted: Mon May 24, 2021 3:44 pm
by hieup2
I want to show you the function of Remote Start on Ford Ecosport 2018+
All you need to do are activating the function with Forscan and programming 4 button key(s) (Lock, Unlock, 2x, and Open trunk); no more equipment required.
Youtube:
https://youtu.be/PjUtrEeebpQ
Re: Remote start for Ecosport
Posted: Sun Jun 27, 2021 1:04 am
by andrew2606
Hi, that's sound great! I wonder how to enter Vehicle Programming Mode? I tried :
- Turn Ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. It's not working.
- press unlock button 3 time, press brake and release then press lock button 3 times, press brake and release but not working too!
My new key is JR3T-15K601-ED, it was able to start the machine but the buttons on remote are not working! Pls help!
Posted: Sun Jun 27, 2021 12:33 pm
by hieup2
You can program the new key with 2 factory keys. Steps:
1. Put the 1st factory key into Armrest box
2. Turn the ignition ON and wait in 3 seconds then OFF (count 1001, 1002, 1003)
3. Remove the 1st key then put the 2nd one into Armrest box.
4. Repeat step 2
5. Remove the 2nd key then put the new key into Armrest
6. Press Startstop button
7. After a couple of seconds, the hardzard light will flash and lock/unlock will trigger. The programming new key is successful.
8. Press Startstop button for ending programming process.
9. That's all!
Good luck!
Posted: Sun Jun 27, 2021 12:36 pm
by hieup2
Any question you can text me to +84909094288 (whatsup or viber)
Happy to help you all
Posted: Sun Jun 27, 2021 12:56 pm
by hieup2
andrew2606 wrote: Sun Jun 27, 2021 1:04 am My new key is JR3T-15K601-ED, it was able to start the machine but the buttons on remote are not working! Pls help!
The frequency of the key is 433 Mhz. What is the frequency of your car?
Posted: Fri Jul 02, 2021 1:11 am
by andrew2606
hieup2 wrote: Sun Jun 27, 2021 12:33 pm You can program the new key with 2 factory keys. Steps:
4. Repeat step 2
9. That's all!
Good luck!
I did the same procedure, system informed successful adding new key but the buttons on remote are not working. Got the key from ebay, frequency is 434Mhz, is it workable ? From F150 forum i found that they changed the frequency from RTM module to get work, but on Ecosport, forscan doesnt show RTM module, dont know how to do! Almost give up ! Any idea ?
Posted: Sat Jul 03, 2021 5:07 pm
by hieup2
The new key is 433 but the factory is 434, so the new key cannot work with your car.
All you need is buying 434 Mhz key. There is no RTM in Ecosport, it is built-in on BdyCM.
I also changed the frequency on my Ecosport, the new key worked with LOCK, UNLOCK buttons, but I could not turn ignition ON as well as open the door with touch; Only pressing LOCK/Unlock worked.
My final solution was buying 434 Mhz key.
Pay attention: the seller said 434 Mhz but in fact, it was 433.92 and coud not work.
Posted: Sun Jul 11, 2021 3:49 pm
by andrew2606
hieup2 wrote: Sun Jun 27, 2021 12:56 pm
I dont understand? My key is 433MHz? Seller said it's 434Mhz! So could you suggest which key is suitable?
Posted: Tue Nov 09, 2021 1:08 pm
by praded2007
hieup2 wrote: Mon May 24, 2021 3:44 pm I want to show you the function of Remote Start on Ford Ecosport 2018+
Youtube:
Hi.
Good hint. But tell me, please, in what configuration is your Ford? s ... se .... titanium??
thanks
Posted: Wed Nov 17, 2021 12:11 pm
by Kkkumar
Subject: Remote start for Ecosport
Youtube:
Can you please provide the part number of the smart key you used here?
Thanks in advance
