Page 1 of 2
2020 Mk4 Focus
Posted: Sun Jul 18, 2021 11:50 am
by Cortinaman
Just bought a Oct 2020 Focus Active X Vignale manual and wondered what changes I can make to the Sync system. I've managed to add the heated steering wheel icon but can't find an option for seats. Also couldn't find one for different coloured buttons for audio, navigation etc... Finally, I fancied changing the splash screen from showing the Ford logo to Vignale or something
Re: 2020 Mk4 Focus
Posted: Sun Jul 18, 2021 10:04 pm
by lenko
APIM 7D0-02-01 xxxx x8xx xxxx - Vignale.
Re: 2020 Mk4 Focus
Posted: Mon Jul 19, 2021 10:00 am
by Cortinaman
Thanks for that, got that working now
Re: 2020 Mk4 Focus
Posted: Mon Jul 19, 2021 10:24 am
by Cortinaman
Just found the heated seat icon setting so have that now. Checked through the menu but don't have an option to change the icon button colours as I've seen some do... I also can't seem to get the speed limit icons to show on the sat nav window as |I've seen done in a video
Any other mods worth doing ?
Re: 2020 Mk4 Focus
Posted: Tue Jul 20, 2021 7:57 am
by davetcollection
Cortinaman wrote: Mon Jul 19, 2021 10:24 am
Classic theme, I believe.
Been an active X Vignale, your APIM start up screen should be Vignale anyway.
Don't use asbuilt codes go in and make changes using the drop down methods
Re: 2020 Mk4 Focus
Posted: Tue Jul 20, 2021 9:08 pm
by Cortinaman
It does now but, when I bought it, it just showing the blue oval Ford logo. I did change it by changing it to an 8 as suggested above which it now shows Vignale but I did also notice it showed that in the APIM as built menu.
While in the APIM as built menu I did try to select the mirrors to dip when selecting reverse but that didn't do anything. Also to display the speed limit on the sat Nav but, again, that didn't work. I did also see a German video about changing the colour of the button icons but didn't have that option on mine either
Re: 2020 Mk4 Focus
Posted: Tue Jul 20, 2021 10:24 pm
by lenko
Try this for speed sign in Navigation:
Navigation Speed Cameras 11-15MY APIM 7D0-02-02 xxx* xxxx xxxx, where "*" make 8=Disabled (Default), 0=Enabled. This was on a Ford Explorer spreadsheet.
Likely the same in newer vehicle. Note what the original number is so you can revert if it doesn't work.
Re: 2020 Mk4 Focus
Posted: Wed Jul 21, 2021 1:24 pm
by davetcollection
Cortinaman wrote: Tue Jul 20, 2021 9:08 pm
Mirror tilt only works on vehicles with memory seat I'm afraid
Re: 2020 Mk4 Focus
Posted: Fri Jul 23, 2021 7:33 am
by JRCondat
Re: 2020 Mk4 Focus
Posted: Mon Jul 26, 2021 7:03 am
by davetcollection
I think it may depend on what lead you are using.
While I was using ELM I would agree, but since I've been using OBDLink EX all the modules now show up
