I test and use (the excellent ! ) FORSCAN on my Transit Mk5 2,5 TD with EPIC injection system.
I also tryed it on others similars models of Transit.
The first feedbacks :
From 1992 to middle 1997 models, it wasn't run and can't connect to vehicle (2 models tested).
The DTC's seem's corrects and true. On one vehicule, I had a trouble code, and after inspection, it's effectively the good problem.
But resetting trouble codes can be a source of confusion. I dont know if it's only on french version ? But when you clear the code, you dont have any feedback and sometimes a failure message (but DTC's are really cleared).
The oscilloscope run well. The bolt up refresh rate look little slow ?
A great feature may be implemented : the boost sensor ?
Best regards.
PS : sorry for my English, I try to do the best I can.
