ON a 2007 Ford C-Max /1.6 TDCI/90 CP/WF0EXXGCDE7T21791 I found at the first search:C1155,C1306 and U2202.
After the erasing of fault memory only U2202 re-appears on ABS/TCM(3M51-2C405-HC).
PCM was replaced on this car(because of a bad battery,a rapid charger was used and PCM was damaged).
What must be done on this new PCM ?On Motorcraft site I can't find as-build code for this replacement PCM(8M51-12A650-LB) .
Thank you.
U2202 on C-Max after PCM replacement
blueoval24
- Vehicle: 2012 Ford Explorer
Re: U2202 on C-Max after PCM replacement
Not sure about your initial question, but using the vin provided, there is asbuilt data available on the ford site
https://drive.google.com/file/d/0B_7wxS ... sp=sharing
Please guide me to write this data into ABS.
I can't write using manual input(gives me checksum error).
The .ab file must be placed in a dedicate folder?
Thank you.
Thank you.
