need to know BCM wire-up for module firmware update.
Posted: Wed May 14, 2025 7:40 pm
by tnap1979
i have a godiag gt100+ and my forscan setup, i also have a dc to dc power supply to supply consistent power to the setup...
my issue is that no matter what, forscan fails at attempt to update bcm, always says vehicle conditions not met
what am i doing wrong ??
i have all the pinouts and diagrams for my 2015 fusion, and i have the 12v-15 lines on what i believe to be ignition line and the 12v30 lines connected to always hot sources like it should, all ground and all canbus are good..
i can see and read the module, but cant even change a single digit in the asbuilt programming, it fails with above mentioned info
Re: need to know BCM wire-up for module firmware update.
Posted: Mon May 26, 2025 10:25 pm
by Rudyrowell
ioterminal has the wiring diagrams for multiple BCMs
https://ioterminal.com/docs/docs/ford%2 ... agrams.pdf
There is a video for cloning it available on YouTube.
https://youtu.be/TQhKXzyfRLs?feature=shared
This does not exactly show how to clone the BCM. You have to pay for access to the full video. I did buy an OBD2 - ECU bench harness
https://autorescuetools.com/products/ob ... ch-harness
They don’t provide support for DIYers.
I have been scouring the web for information on this process.
