2025 Isuzu dmax - Cannot input ECU number
Posted: Thu Nov 06, 2025 3:40 am
Hi all.
First time here. I believe that Forscan should work with my vehicle (effectively rebadged Mazda BT-50), but the application doesn't recognise the ECU automatically, nor does it accept the ECU number when entered manually.
I suspect that this is likely due to a change of ECU manufacturer - the part number is not in the "Bosch" xxxx-xxxx-xxxx-xxxx numeral and letter format, but one complete 10 digit number.
I'm using the Vgate vLinker OBD2 adaptor.
Any input greatly appreciated.
Thanks in advance.
B
Thanks in advance.
B
