Attempting to modify and write values ​​to the HVAC module using FORScan failed.
Posted: Sat Mar 21, 2026 5:11 am
by guangzhouhuakai
In FORScan version V2.4.22beta, after modifying values ​​in the HVAC module and attempting to write them, I received a prompt stating that the service routine had been interrupted. The hardware I am using is an OBDLink EX, with the firmware updated to the latest version. Does anyone know what might be causing this? Writing modified values ​​to the BCM module works without any issues. The vehicle is a 2023 Ford F-150 (3.5TT Gasoline).
Re: Attempting to modify and write values ​​to the HVAC module using FORScan failed.
Posted: Wed Mar 25, 2026 8:05 am
by guangzhouhuakai
Today, I successfully modified and wrote values ​​to the HVAC module on a 2024 F550; however, for some reason, the HVAC module on a 2023 F150 would not allow the write operation.
