Vint adaptor and abs bleed
The vint adapter is not working properly when trying to bleed abs, I have beta version for forscan and not sure what I'm doing wrong. I saw a tutorial and that tutorial at least show an option to choose of what was done before performing the bleed and on my end I don't get that. Should I buy anotehr adaptor? I do get code B1342 and plan to possibly replace but that means I would need to copy the info of the abs module my vehicle has now and I'm not sure on how to copy that info and transfer to the new abs module that I'm awaiting for.
Re: Vint adaptor and abs bleed
Would help to know what vehicle you are working on. Also, what adapter you are using. B1342 is a faulty ABS module. Only replacement will fix that.
