Forscan power change will I loose remap
Stuart08031989
- Vehicle: Transit custom euro6 2.0 130ps 2020
Hi allI have a transit custom 2.0 ecoblue 2020. I changed the power from 130 to panther 185 then later I had it remapped and ad blue delete and egr off. If I switch the power setting in forscan will it delete the remap or does it just switch between the power map on ecu. Reason I ask is would the remap change the original 130 map or the panther one set on forscan. If I selected the original 130 to see if any difference then go back to panther does forscan overwrite stock files or just switch in ecu
