CAN@T READ/ ACCESS ICU
Posted: Thu Apr 27, 2017 4:18 pm
by Geordie-scanner
hello all,
I have a mk3 Mondeo 2006 TDCi
so I've got the latest version of forscan on the laptop now 2.3.8 B
Connection to the car.....OK
can bring up data on the PCM in the dashboard of forscan
But has ISSUES with ICU
It just tells me to connect to the car and turn the ignition on
Same issue with the tests
PCM ....OK
IC .....OK
ICU - "the conditions are incorrect"
I'm in a situation where I have to do injector work, but can't!
pls help or update software
(WARN) [15:29:31.634] Checking COM4...
(OK) [15:29:32.251] Connection to adapter has been established: COM4
(OK) [15:29:32.252] Adapter: ELM327 v1.4
(OK) [15:29:33.212] Connection to vehicle has been established
(OK) [15:29:35.760] Vehicle: Ford Mondeo Duratorq Turbo Diesel Common Rail Injection 2.0L 2006 ( 2001 MY ), VIN: WF0*********83025
(OK) [15:29:36.474] Found module: OBDII - On Board Diagnostic II
(OK) [15:29:36.732] Found module: PCM - Powertrain Control Module
(WARN) [15:29:36.814] DTCs in PCM: P132B, P132B
(OK) [15:29:36.818] Found module: ICU - injector control unit
(OK) [15:29:37.596] Found module: IC - Instrument Cluster
(OK) [15:29:38.781] Found module: RCM - Restraint Control Module
(OK) [15:29:39.899] Found module: GEM - Generic Electronic Module
(OK) [15:29:43.323] Found module: ABS - Antilock braking system
(OK) [15:29:56.338] Successful DTC reset, DTCs will be read now...
(OK) [15:30:10.648] Live data streaming...
(ERR) [15:30:10.680] Unable to run data stream. Please make sure
the ignition key is ON and try again
(OK) [15:30:30.312] Live data streaming...
(ERR) [15:31:03.151] Test has been interrupted, please contact developers
(ERR) [15:31:11.726] Test has been interrupted, please contact developers
(ERR) [15:31:30.715] Test has been interrupted, please contact developers
(ERR) [15:31:44.343] Test has been interrupted, please contact developers
(OK) [15:32:14.917] Disconnected
