Page 1 of 20
Posted: Fri Jun 23, 2017 11:28 am
Here are some very helpful resources created by enthusiasts:
Note: As Built format function was first of all designed for restoring factory configuraiton (As Built data). It was not designed for custom configuration. For inexperienced users we strongly recommend to use Module Configuration functions in FORScan that lists the configuration parameters in a user friendly way.
1. Tutorials:
Great FORScan tutorial created by Livnitup from F-150 forum. It was developed for F-150, but the principle of work with As Built data can be applied to any model.
2. As Built decodings
2011-2014 F-150 by unknown author
2015+ F-150s created by Livnitup from F-150 forum.
2013+ Fusion created by DanMc85 from 2GFusions forum.
2011+ Explorer's created by PlatinumOwner from the Explorer forum
2017+ Ford Super Duty models F250, F350 and F450 created by EpicCowlick from Ford Trucks forum.
2013+ Ford Flex FORScan mod spreadsheet - not maintained anymore.
2010+ Ford Taurus FORScan mod spreadsheet - page seems to be removed by authors. If you know new address, please let us know.
3. Related threads on enthusiasts forums
FORScan - software to enable/disable features in your truck - Ford F150 Forum - Community of Ford Truck Fans
2GFusions HOW TO: FORScan - Modify Module As-Built Data
Ford Trucks FORScan Spreadsheet
Ford Flex FORScan thread
4. Helpful 3rd party software
As Built Explorer by Jesse Yeager. This tool helps to compare, analyse and explore As Built data. Motorcraft's *.AB and and FORScan's *.ABT formats are supported.
5. Official resources
Motorcraft - Module As-Built Data (returns Ford factory data by VIN, also works for Mazda trucks, Tribute and 2003-2013 Mazda 6 )
Mazda Service Info - Module As-Built Data (returns Mazda factory data by VIN, except trucks, Tribute and 2003-2013 Mazda 6 )
6. Other resources
Sync 3 APIM Programming
Posted: Sun Sep 24, 2017 10:06 pm
by isaacknopfler
link ro Ford Flex FORScan thread https://www.fordflex.net/forums/viewtop ... =3&t=17209
link to Ford Flex FORScan mod spreadsheet https://docs.google.com/spreadsheets/d/ ... sp=sharing
Posted: Sat Nov 18, 2017 2:25 am
by marszallek
Hi, do you know that codes for programming from Ford Explorer platinium works for Ford Fusion ?
There are some code on 2gfusion forum side but much more are for Explorer.
Could you please share the experience ?
Posted: Mon Mar 05, 2018 2:35 am
by BIG ANGRY HILLBILLY
Trial and error. A lot of the stuff is the same across multiple platforms, try it and you'll know if it works or not fairly quick.
Make sure you back up your existing configuration data before you play around with it.
Posted: Sat Mar 31, 2018 11:00 am
by 17LimitedExpy
Here's a link to the Google Doc I've put together for 2015-2018 Ford Expeditions...Admin, please include in the original (first) posting if you think it's valuable to other Expedition owners.
Thanks.
Posted: Sun Apr 15, 2018 3:21 pm
by Golfman454ss88
I wish there was a spreadsheet for escapes.
Posted: Sat Apr 21, 2018 3:44 pm
by cypher0807
Thanks great for the 3rd Gens, nothing for Gen 1 and 2's... this sucks
Posted: Sun Apr 22, 2018 9:02 am
by nguyentattiep
I need As Built decodings for FORD RANGER and everyone can help me
please
Posted: Sun Apr 22, 2018 10:49 am
by Golfman454ss88
nguyentattiep wrote:I need As Built decodings for FORD RANGER and everyone can help me
please
What you need is at the top in the directions option #4, Official Resources.
Posted: Sun Apr 22, 2018 12:32 pm
by Shadowman
Hallo zusammen....
Gibt es hier eine Übersicht, wenn möglich mit deutscher Erklärung, über die einzelnen Punkte die man an einem Kuga MK2FL verändern kann?
In Forscan sieht man nur Zahlen und Buchstaben...Ich habe mit einiger Hilfe das Logo sowie die Klimasteuerung im Sync-Display bereits geändert...schön wäre es noch wenn ich Speedlook, automatisches Verschließen, und Deaktivierung des Heckscheibenwischers einstellen könnte. Geht auch die Einstellung von 150 PS auf 182 PS beim Benziner? Was kann man noch einstellen/verändern?
Danke für eure Hilfe....mein Englisch ist b´nicht mehr ganz frisch...bin ja schon ein paar Jahre aus der Schule raus und habe kein Englisch gebraucht!
Vielen Dank!!!
