Posted: Fri Mar 30, 2018 9:52 am
Update 2019-12-11. Article updated as the following:
- Added reference to OBDLink EX
1. Protocols
Table 1.1 - Ford protocols
P - primary protocol (PCM)
2. Performance
3. Reliability
4. Recommendations
P - recommended for programming: complex configuration, firmware update (only for CAN )
* - can be modified for MS-CAN support as described here.
5. Links to original adapters
All of these adapters were tested by us.
5.1. OBDLink product line: https://www.obdlink.com/
5.2 ELS27: http://els27.ru
5.3. Viaken: https://viaken.pl/pl/polski-elm327-v3-f ... -2014.html
1. Protocols
| OBDII name / Ford name | OBDII jack pins | Bus speed | Bus min. response time | How to detect |
| SAE J1850 PWM / Ford SCP | 2, 10 | 41600 bps | 20...40 ms | ![]() |
| ISO9141 / Ford ISO | 7 | 9600 bps | 150...250 ms | ![]() |
| CAN / Ford HS CAN | 6, 14 | 500 Kbps | 0...20 ms | ![]() |
| / Ford MS-CAN | 3, 11 | 500 Kbps | 0...20 ms | ![]() |
| / Ford UBP | 3 | 10400 bps | 150...250 ms | ![]() |
| Generation | SAE J1850 PWM | ISO 9141 | CAN | Ford MS CAN | Ford UBP | Comment |
| Ford 1996 - 2003 | P | S | - | - | - | |
| Mazda 1996 - 2003 | - | P | - | - | - | Some models used SAE J1850 PWM as primary |
| Ford EU, Mazda 2004 - 2009 | - | S | P | S | - | Some models used SAE J1850 PWM as primary |
| Ford NA 2004 - 2009 | - | S | P | S | S | |
| Ford, Mazda 2010+ | - | - | P | S | - | HS2, HS3 through MS-CAN |
| Focus Mk2 - only HS-CAN and MS-CAN | Mondeo Mk3 after restyling - J1850, ISO9141, HS-CAN, MS-CAN |
| Chip | SAE J1850 PWM | ISO 9141 | CAN | Ford MS CAN | Ford UBP | Adapter |
| ELM327 standard | X | X | X | - | - | ELM327, Kiwi 3 |
| ELM327 with HS/MS switch | X | X | X | X | - | ELM327 marked as Ford, Mazda compatible |
| STN 1100 | X | X | X | - | - | OBDLink SX/LX |
| STN 115x | X | X | X | X | - | OBDLink MX BT |
| STN 1170 | X | X | X | X | - | ELS27 (old versions), Viaken STN1170 |
| STN 2120 | X | X | X | X | - | ELS27 (new version) |
| STN 2255 | X | X | X | X | - | OBDLink MX+ |
| STN 2230 | X | X | X | X | - | OBDLink EX |
2. Performance
| Adapter | Chip | Interface | Min.interface response time | Max.interface baud rate | Comment |
| ELM327 OHP HS/MS WiFi | ELM327 (clone) | WiFi | 30-40 ms | 38400 bps | Unknown manufacturer - "good clone". Recommended only for iOS |
| Kiwi 3 | ELM327 compatible | Bluetooth Low Energy | 40 ms | - | Can be used only with FORScan Lite for iOS |
| ELM327 HS/MS USB | ELM327 (original) | USB | 0..2 ms | 500 Kbps | |
| OBDLink EX | STN2230 | USB | 0..2 ms | 2Mbps | Recommended for FORScan for Windows |
| OBDLink SX | STN1100 | USB | 0..2 ms | 2Mbps | |
| OBDLink LX | STN1100 | Bluetooth | - | - | |
| OBDLink MX+ | STN2255 | Bluetooth | 6..20 ms | - | Recommended for FORScan Lite for iOS, Android |
| OBDLink MX BT | STN115x | Bluetooth | 8..20 ms | 115200 bps | |
| OBDLink MX WiFi | STN115x | WiFi | - | 115200 bps | WiFi interface works unstable - it freezes and times out. Strongly not recommended! |
| ELS27 v3 | STN2120 | USB, Bluetooth | 0..2 ms USB, 20 ms BT | 8 Mpbs USB | |
| Viaken STN1170 USB | STN1170 | USB | 0..2 ms | 2 Mbps | Last versions of this adpater have buggy firmware 4.3.x. Recommended to downgrade to stable 4.1.1 or upgrade to stable 4.5.1 |
| Viaken STN1170 BT | STN1170 | Bluetooth | 20..30 ms | 38400 bps | Uses cheap BT chip so may freeze on some cars. Not recommended |
Examples:
4. Recommendations
| Adapter | FORScan for Windows | FORScan Lite for iOS | FORScan Lite for Android |
| OBDLink EX | D, C, P | NO | NO |
| OBDLink SX | D, C, P* | NO | NO |
| OBDLink LX | D (if MS-CAN is not required) | NO | D (if MS-CAN is not required) |
| OBDLink MX+ | D, C | D | D |
| OBDLink MX BT | D, C | NO | D |
| OBDLink MX WiFi | NO | NO | NO |
| ELS27 v3 | D, C, P | NO | D |
| Viaken STN1170 USB | D, C, P | NO | NO |
| Viaken STN1170 BT | NO | NO | NO |
