FORD FUSION 2017 BRICKED BCM - WRONG CONF FILE LOADED
Posted: Sat Apr 14, 2018 2:19 pm
by natcorporation
Ford Fusion 2017 bricked BCM - Wrong conf file loaded
I have problem with Ford Fusion 2017. I read original configuration file from BCM.
Mistakely I write wrong configuration file from another Ford - I have file in the same folder ( nevermind ).
Now - Car won't start and don't see key. I flash BCM with vbf loader but I must write original configuration. Please help me - is option to write conf file to BCM without ignition ?
VIN: 3FA6P0HD8HR128405
BCM PART NUMBER : GU5T-14B476-CAJ
Please anybody help ..
I attached as built data from forscan in rar
Re: FORD FUSION 2017 BRICKED BCM - WRONG CONF FILE LOADED
Posted: Sat Apr 14, 2018 10:15 pm
by twisterrescue
TRY to find as built on motorcraft service by vin# copy and hope for the best
Posted: Thu Apr 19, 2018 8:31 pm
by DVeldma
Hi Natcorporation
Did you get sorted out with this and back u and running?
The site that we're talking about to get access to your original As-Built data for Forescan to upload is @ https://www.motorcraftservice.com/AsBuilt (put you car VIN # in their and it will display as well as let you download the correctly formatted As-Built data file for you to use for your vehicle.
that being said, if your key isn't recognized, then I am not sure how you get your vehicle into accessory mode in the forst place in order for Forscan to communicate to with your OBD-2 connector in the first place. If you know someone who has the same vehicle year and model you have, you maybe able to reflash you module via his vehicle, but at that stage, I'd be dragging it off to the dealer and confessing of your sins.
Posted: Sat Apr 21, 2018 11:30 am
by natcorporation
I buy account on FJDS Ford motorcraft service - USA for 2 days - reprogram BCM with Programable module Instalation - BCM - everything fine but configuration not upload done - Maybe anybody have solution ?
I think it's two important things keys and vin - I try open BCM module and check what memory is in. If eeprom I read it and check what data is in it. I know - to write back configuration or as built - must have access - ignition and working key. Ok try and give results.
thanks for info
Posted: Fri May 14, 2021 10:01 am
by Idumbakumar
Hello buddy so how did u recover the bcm now. We have in same situation on KA+ active. Trying to recover.
Fed 12v to the ignition pins didnt work. Pls let me know how did you recover it?
