Nav Fault on sync 3
Posted: Thu Apr 19, 2018 2:09 am
by ssrhwm
This is my first forum. I am sorry if this question or issue has been asked/answered before. I looked all over and could not find a resolve for it.
My issue is, on my 2016 F150 with Sync 3, I used forscan to enable Nav however when I try to use nav, it tells me nav isn't functioning properly. Is there something I'm doing wrong or??? Help!!
Re: Nav Fault on sync 3
Posted: Thu Apr 19, 2018 12:39 pm
by Vladsky
Howdy.
1. This is the Beta Testing section - yer in the wrong forum. (Perhaps PM a Mod/Admin to move/merge yer two threads on this same topic.)
2. The only way to 'enable' NAV on Sync 3 is to have a NAV-capable APIM. If you don't, it's not possible to 'enable' it with anything. ( Exception - adding internal hardware to the mobo ).
3. Yer a little light on details - provide screenshots of the errors and other details (code/pics/etc) on what exactly you are attempting via Forscan. No reason or excuse not to - if you actually want cogent help as we cannot 'see' yer situation over the innernet thang. PLUS - This is assuming you swapped the APIM with a NAV-capable unit. Da?
4. Assumin' #3 is true, go look at the Forscan Sticky on F150Fourm - including the spreadsheet. Additionally, there are several Sync3-specific threads in that truck forum discussing this exact topic (making a swapped-in NAV-capable APIM function), Answer is there - posted many times.
5. Depending on yer errors - guessing here as you did not provide any specifics - check GPS connections/functionality. Run bezel diags on the APIM; that procedure is clearly posted on that forum and elsewhere - it's everywhere. Snag and post those screens as well. Sorry - I don't believe in spoonfeeding - I believe applied self-help is the best way to learn and retain knowledge.
BTW ... this:
http://forscan.org/forum/viewtopic.php?f=5&t=6308 is called cross-posting. It's not cool as it clutters the forum with duplicate nonsense. Next time, review the various forum sections, pick the appropriate one (in this case it's the Config & Programmin' one) and stick with it. Just sayin', Aight?
Salut
Vlad
Posted: Thu Apr 26, 2018 11:21 am
by rainlord
ssrhwm wrote:This is my first forum. I am sorry if this question or issue has been asked/answered before. I looked all over and could not find a resolve for it.
Your GPS module may be faulty or not functioning properly. I had the same issues, but most of the time the nav would start working after a few minutes. I bought a new "Fakra plug" GPS module on Amazon and plugged in (attached it to top of metal cross-beam that's just behind the sync3 unit, with the magnet (so that the top of the module points to the sky) and I've not had the problems since.
Posted: Thu Mar 28, 2019 2:58 am
by Ramper
found fix ????
try eject+seek -> go to test setting ->remove navi fault .
Posted: Sat Sep 21, 2019 12:45 pm
by davehawthorne
The cheaper GPS Antenna's did not work for me (tried 2 of them). The Xtenzi one did!
I was finally able to clear the DTC (B119F:13-0B) after I installed the antenna.
Xtenzi Active Clarion External GPS Antenna
https://www.newegg.ca/p/0N1-00BC-00016
Hope that helps someone. I know I looked for awhile to find the solution to the issue when I did the upgrade from a Sync 2 to Sync3 and encountered the Navigation Fault error.
Posted: Fri Feb 04, 2022 11:28 am
by AFR
The sync has to go into power shutdown mode and then reboot when key or button pressed. Sometimes have to disconnect -ve terminal, when the power relay wont de-energise.
Posted: Fri Jul 01, 2022 8:48 am
by LaForge
ssrhwm wrote: Thu Apr 19, 2018 2:09 am
You cannot add Navigation on a NON Nav Device.
It can be done with a hack in Sync 2 but NOT in Sync 3.
There you need more Memory. I guess it can be welded onto motherboard but it seems easier to get another apim with nav memory.
Best regards
Karsten
