ford fusion 2015 foglamp
Posted: Wed Sep 12, 2018 4:09 pm
Hi all, I have a 2015 Ford fusion that did not come with fog lamps , I have replaced the switch with a new one that contains the fog lamp switch but I don't think the bcm is coded correctly for it to operate as I do not get an indicator on the dash and the harness does not send power. can anyone tell me what should be changed in encodings, so that the fogs work? Thank you
