Tire pressure sensors
carlus
Post by carlus »
Hi.
My car has a sensor in each of the wheels so that if one wheel downward pressure required minimum car alert you that has a low pressure wheel but does not indicate which wheel is the one below required pressure. Does the application forscan one pid for each wheel with the pressure of each wheel?
A lot of thanks.
MAZDA cx7 diesel
Re: Tire pressure sensors
You should have PIDs AI_WU1_P-AI_WU4_P in HEC module. Do you see them?
carlus
Post by carlus »
FORScan wrote:You should have PIDs AI_WU1_P-AI_WU4_P in HEC module. Do you see them?
The HEC module does not have built-in Mazda CX7 2.2 Diesel (Use OBDLink Bluetooth adapter MX), but I found several PIDS in the IC module which I understand are those that can provide such information (WU1_P, WU2_P, WU3_P and WU4_P). I have to try them since I 'm on vacation. At the moment can I connect to the car and confirmed in this thread, this PIDs work correctly.
Thank you very much and greetings.
MAZDA cx7 diesel
carlus
Post by carlus »
Ok, PIDS (WU1_P, WU2_P, WU3_P and WU4_P)are corrects. ;)
Thanks you!.
MAZDA cx7 diesel
