Page 1 of 2
No audio from phone calls-sync1 2017 Fusion
Posted: Tue Dec 18, 2018 6:11 am
by LahainaOhana
2017 Fusion, Sync I. Android phone connects fine through Bluetooth. Audio music and notifications play through the system from phone, voice commands work, however when I receive and answer a call through the system, other party can hear me talking, but I cannot hear them. Volume up or down nothing. I have to hit the "privacy" button and listen through the phone. I've been through the menus looking for a mute...nothing. Any help anyone can give me?
Re: No audio from phone calls-sync1 2017 Fusion
Posted: Wed Jan 09, 2019 2:06 am
by LahainaOhana
I did some wiring diagnostics, and all the audio connections between the sync module and the audio module are good. I am realizing that I'm not getting any voice notifications from the sync system. It won't read texts, confirm actions, or pass through telephone calls, or my answering system, however Bluetooth music, and books come through just fine. Does anyone know Ford's logic for the sync system? When a call comes in the audio is totally dead, no hiss or any indication that it's trying to pass audio through.
Posted: Wed Jan 09, 2019 2:11 am
by LahainaOhana
Does anyone have a spreadsheet for the APIM commands?
Posted: Wed Jan 09, 2019 2:50 am
by twisterrescue
check cars settings make sure do not disturb is not on .
Posted: Wed Jan 09, 2019 3:39 am
by LahainaOhana
I have sync1. Can't find a "do not disturb" setting. My system allows incoming calls, allows me to answer them, but I have to hit the "Privacy" button to hear the other party through the phone directly.
Posted: Wed Jan 09, 2019 2:34 pm
by Ptrck600
Try answering the call through the sync and adjust the volume by using the phone volume buttons
Posted: Thu Jan 10, 2019 12:24 am
by LahainaOhana
Volume on phone or on system is up and there is no sound, not even a hiss.
Posted: Thu Jan 10, 2019 8:13 pm
by LahainaOhana
I fixed the problem. I had replaced the ACM from a wrecker and of course it was programmed for the vin it came out of. I downloaded my as-built code, loaded it into my ACM and WALA! I can hear audio from my phone!!! I also changed the code in my ACIM module which was also from a wercker. This software has saved me a mint. Thanks FORScan!
Posted: Wed Feb 20, 2019 3:33 am
by furletti
I am having the same problem after installing an ACM from a wrecker after my ACM died. I’m new to FORscan. How do I get the ACM code from my as built data to put into my replacement ACM. Like your problem, I can make calls and they hear me but I can’t hear them. Also, when I press the Command button on my steering wheel I do not get the voice prompt from Sync but Sync hears me and follows my commands. Thanks in advance for the help.
Vehicle is a 2015 F150 Lariat FX4.
Posted: Wed Feb 20, 2019 8:14 am
by Carstenth
what about normal radio could you hear that or was it only phone you could not
