Forscan 2.3.20 PCM - Reset all adaptation not working
Posted: Mon Feb 18, 2019 1:30 pm
by hudarsono
I just tested this new functionality (PCM-Reset all adaptation) for my vehicle Ford Ecosport Ti-VCT 2014.
However after the service run up to 4%, there is error saying "Service procedure has been interrupted".
While running the procedure, vehicle is on Key On Engine Off and using usb ELM327 adapter with MS-HS CAN switch. I am not connected to internet while running the procedure.
I can run other function such as read DTC or PID just fine.
Any advice?
Thank you,
Re: Forscan 2.3.20 PCM - Reset all adaptation not working
Posted: Mon Feb 18, 2019 7:04 pm
by f-wolf
Posted: Tue Feb 19, 2019 7:36 am
by hudarsono
I have done some google search before posting. Could you point me to more exact link?
To add info: I am doing this because I just solved vacuum leak issue, and cleaned throttle body. So PCM need to re-learn.
Posted: Tue Feb 19, 2019 11:44 am
by Andyfocus
have you tried leaving the battery disconnected over night ?,
or disconnect battery both terminals and place a bulb in the middle for 1 or 2 secounds then touch both terminals together for around 10 secounds . ( bulb isnt really nessaccery but helps to prevent damage to the electrics by drawing the current out instead of just straight threw terminals )
Posted: Tue Feb 19, 2019 8:23 pm
by Andyfocus
just been out and done a reset and relearn on mine all worked ok , would suspect a dodgy adaptor on your end if it still isnt working .
Posted: Sun Feb 24, 2019 12:24 am
by hudarsono
Thanks, it seems like disconnecting the battery is the way to go. I was thinking of not using that, but as they would require a extra work to remove stuff.
