PDM,ddm module ubdated
marekrbk
Vehicle: Ford Mondeo mk5 110kw ,2020
Post by marekrbk »
Mondeo mk4 1.8tdci 2007 92kw
Forscan 2.4.0 test20190403
why this? after update code: u0300
is a solution?
:idea:
nurex
Vehicle: Ford Mondeo MK4
Re: PDM,ddm module ubdated
Post by nurex »
I have the same problem.
Is there a solution???
Ptrck600
Vehicle: F150/3.5/2016
Post by Ptrck600 »
marekrbk wrote: Mon May 06, 2019 1:01 pm Mondeo mk4 1.8tdci 2007 92kw
is a solution?
:idea:
Try what the troubleshooting says.
Run CCMii sensor alignment service function
marekrbk
Post by marekrbk »
such a feature is not supported forscan
marekrbk
Post by marekrbk »
I updated the modules with original calibrations. all without mistakes. using ucds cable
Snímka obrazovky (9).jpg (22.62 KiB) Viewed 8621 times
marekrbk
Post by marekrbk »
return the original calibration,error u0300 removed.
folding rearview mirrors the function expires. if you want the function again, update only DDM
danczx7841
Vehicle: mondeo mk3 125 bhp 2009
Post by danczx7841 »
marekrbk wrote: Thu Mar 05, 2020 6:01 pm return the original calibration,error u0300 removed.
Hi have you got the files to download
danczx7841
mtech
Vehicle: 2018 Ford F-150
Post by mtech »
I had some DTCs after flashing new firmware to PDM. The PDM was inop after flash, no normal functions.
The flash was successful, but was getting a few DTCs on the PDM, including 'Missing Calibration'. The PDM was not responding correctly, as I could not activate the power fold mirrors on the passenger side.
What I found is that the As Built configuration went to some default state after the firmware flash. I restored from a backup I made earlier and then the PDM started to work normally with the new firmware. DTCs went away.
nurex
Post by nurex »
I have the solution for U0300.
If you update DDM and PDM to software with the last letter E or F, then the rear modules must have the same last letter. After that, the U0300 DTC is gone
