I am trying to find information on how to add language localization to the IPC module.
Last time I upgraded the unit using calibration files -JS7T-.
Here, however, only the appearance was modified and the function of a digital speed indicator was added.
The range of languages remained unchanged.
I also tried to rewrite the region code in AS BUILT IPC, but that didn't help either.
So I understood that simply the calibration files themselves do not contain the given language localization and it is necessary to add it manually by editing the VBF files themselves.
Is there anyone here who could help me with this?
How would I be able to transform individual vbf files into text --> translate --> and then save as vbf?
Or is there another procedure for this?
Many thanks in advance for your help.
Translate/ADD language for IPC
guangzhouhuakai
- Vehicle: ford F550 7.3L 2020
Re: Translate/ADD language for IPC
romboid5b wrote: Fri Nov 24, 2023 8:18 am Hello,
福特进无止境
guangzhouhuakai
I also encountered the same problem, has your problem been solved?
福特进无止境
You have to translate a language, into the language of your country. In the vbf file
guangzhouhuakai
Hello, do you have a detailed tutorial? I have VBF editor version 2.2. Cannot open VBF files for vehicles manufactured in 2023claumedel wrote: Sat Feb 24, 2024 7:09 pm You have to translate a language, into the language of your country. In the vbf file
福特进无止境
Hello, to solve any problem regarding the process of changing the language for the 2013 model year, please send me the type of car, the model, the chassis number, and the shape of the car. ipc
guangzhouhuakai
VIN:2LMHJ5AT0DBL52540 The 2013 Lincoln IPC module needs to add Chineseziadal wrote: Sun May 26, 2024 8:37 pm Hello, to solve any problem regarding the process of changing the language for the 2013 model year, please send me the type of car, the model, the chassis number, and the shape of the car. ipc
福特进无止境
Miguel Louzan
- Vehicle: Ford Mustang, coyote, 5.0 425cv 2016
guangzhouhuakai wrote: Sun Feb 09, 2025 8:20 amziadal wrote: Sun May 26, 2024 8:37 pm Hello, to solve any problem regarding the process of changing the language for the 2013 model year, please send me the type of car, the model, the chassis number, and the shape of the car. ipc
hello, I have a mustang gt350 Shelby 1fa6p8jz0h5522164 year 2016, I would like to have the German language on ipc, currently it has English, French and Spanish, I can change Spanish to Portuguese but not German. Can someone guide me? thank you
PelsonBM
- Vehicle: Ford Escape 2020 MK4 250hp 2.0 EcoBoost
Have you found a solution ?
