How to reset/calibrate matter particulate sensor after replacement
vince59
Vehicle: BMW x3 190 hp - alf stelvio 280 hp - ecosport 125 hp
Post by vince59 »
As per title, I am going to replace the particulate matter sensor on a Ford ecosport diese 1.5 92kw. I have been told that the ECU needs to be resetted or calibrated after replacing such item.
Is this possible with ELM 327 and FORscan free version?
boosted_diesel
Re: How to reset/calibrate matter particulate sensor after replacement
Post by boosted_diesel »
I'm pretty sure you could reset the pcm learned values with what you have although I'm not 100% on it that will reset what your after. Give it a try maybe?
kosta07
Vehicle: ford fokus m4 1.5 tdci econetic
Post by kosta07 »
Did you succeed?
