Adaptation tables in Forscan as in ForDIAG
opexa
Vehicle: Focus ST170
Post by opexa »
do you plan implementing of detailed view of the adaptation tables as there is in ForDIAG?
I have both tools but they can't be used simultaneously. The adaptations/KAM tables can reveal information about a problem in the vehicle, or shot that there is such in the first place, when it's not easy to see it just by looking at the parameters and no trouble codes. Most of the times it's about vac leak so small that can't be detected but it's compensated in the adaptations and only there it can be seen, especially if its mostly at particular engine load.
Thank you
Re: Adaptation tables in Forscan as in ForDIAG
Contact the developers. This will take some creative thinking and may need a specific interface.
ELM devices may not even keep up with the data transfer, let alone the various models out in the market.
Generally, a high end or decent tuning tool can access the tables, the creative thinking is placing the relevant data on the screen.
Aussie_au3
Vehicle: Falcon au3 4.0
Post by Aussie_au3 »
this needs to added .. i asked about this a while ago and not one person responded
Aussie_au3
BUMP..
is there any update on this?
why no interest?
