I’ve had Forscan for years now, using an ELM327 v1.4. Since the last update to Forscan every time I connect it states the adapter is not compatible with my vehicle (which I’ve used the same setup frequently with it prior to the update without issue). When it gives that message, Forscan cannot read faults and doesn’t allow for tests.
So, the question is; what is the newest compatible Bluetooth adapter that will work with a Microsoft Surface tablet running windows10Pro?
