I have 4 x Mazda's, 1 x Audi TT 1 x Mitsubishi vehicles so my guess is to only use the vgate vlinker hardware you spoke of earlier? Am I correct?oldtinfords wrote: Sun Jul 20, 2025 2:57 am If you plan on using Ford tuning software eg PCMtec or other Ford software where a J2534 cable is used, I'd look at the OBDX Pro FT. I use one of these, but they are a bit more expensive
https://obdxpro.com/product/obdx-pro-fx ... nd-tuning/
- 2007 MZR-CD
- Vehicle: 2006 Mazda6 & 2007 Mazda3 MZR-CD Diesel 2000cc
Australian 2006 Mazda 6 Wagon MZR-CD Turbo Diesel
Australian 2024 Mazda 6 Wagon GL Sport 2.5 Petrol
Australian 2007 Mazda 6 Wagon MZR-CD Turbo Diesel
oldtinfords
The vLinker is cheap & is going to be ok for any vehicle supported by FORScan. The audi & mitsubishi will require different software & adapters.2007 MZR-CD wrote: Sun Jul 20, 2025 3:36 amI have 4 x Mazda's, 1 x Audi TT 1 x Mitsubishi vehicles so my guess is to only use the vgate vlinker hardware you spoke of earlier? Am I correct?oldtinfords wrote: Sun Jul 20, 2025 2:57 am If you plan on using Ford tuning software eg PCMtec or other Ford software where a J2534 cable is used, I'd look at the OBDX Pro FT. I use one of these, but they are a bit more expensive
