Getting a gain security access failed - security key is wrong.service procedure has been interrupted message when's trying to flash IPC module, I have the free extended license does the paid versions take care of this?
2025 Bronco Raptor
Security key is wrong
Powerstroke Racer
- Vehicle: Bronco Raptor, 3.0 V6 TT 418hp 440 TQ 2025
- Contact:
Re: Security key is wrong
I cant say for sure that is the issue. I can say that I was getting the same error when I was trying to program 2 new keyfobs to my Escape, and when I looked into the error, it stated that the free extended liscens was not supported for that procedure.. So my guess is that you are having the same issue..
did you ever figure this out? I have a 2025 bronco and am attempting to write the ipc. I have the extended temp license and get the following error. Gain security access failed. security key is wrong. is this something new ford is doing to block changes with forscan?
