Hi can anyone help with these codes, not noticed these codes before. I have recently updated IPC on my mk5 mondeo 1.5tdci and ive been enabling or disabling somethings and im not sure if these are a result of that. Any help very much appreciated
These are what i have used
0-EJ7T-14C025-AA.vbf
1-JS7T-14C026-AJB.vbf
2-JS7T-14C026-BJB.vbf
3-JS7T-14C088-AJB.vbf
4-JS7T-14C088-BJB.vbf
APIM U0155:00-2B / APIM U2101:00-2B
Re: APIM U0155:00-2B / APIM U2101:00-2B
Quick update I've managed to sort it and would like to share if anyone else has the same problem. I loaded factory AB in APIM module and reset fault codes and its all sorted
- fordsmax471
Glad you got it sorted
What year is your car and do you have sync 2 or 3?
2015 sync 2
Does anyone have the original apim and ipc files or can point me in the right direction? I have uk 65 plate mondeo 1.5tdci titanium. I have noticed reloading factory ab the reverse camera doesn't work. Ive tried enabling but then i get the same codes as before
Another update
How come there is a lack of help on this forum???
Anyway i have finally sorted it with no error codes with camera and parking sensor display both working, my problem was the as-built data wasn't quite right on 7D0-01-01 line. I used the following links to help fix the issue.
https://www.motorcraftservice.com/asbuilt
https://docs.google.com/spreadsheets/u/ ... true&pli=1
