The rear right turn dignal is disable.The front right work properly.What I m doing to fix ir.
My Ford edge 2013 SEL has a problem with Rear right turn signal ,thats no funtion1 got the veichule to the mechanic a he said thats the problem with de BCM. I rey to to buy a new o e,but the part is descontinue.The question is ,what I do to resolve the problem,Is posible to te programan the module.What is recomend.Thanks.
Baddjack
- Vehicle: 2012 F150 FX4, 5.0l SuperCrew 6.5' bed, 360hp/380 lb-ft tor
- Contact:
Re: The rear right turn dignal is disable.The front right work properly.What I m doing to fix ir.
Have you had any luck finding a solution to this I have the same situation
Mareng
- Vehicle: Mazda 6 Diesel, 2.2, 2014, Britain
Do all your hazard warning lights work?
Have you checked the lamp, does that work ?
Mareng
go to a scrap yard & get a used one
