2020 Ford Escort issue, when tried to update any module firmware or pats programming I got error messege
log files
(OK) [23:16:50.888] GWM Module firmware update has been started
(WARN) [23:16:50.900] Reading vehicle info...
(WARN) [23:16:56.956] Downloading firmware files from the Internet...
(ERR) [23:16:58.981] Downloading CM5T-14F532-AA: ERR
(ERR) [23:16:59.994] Downloading JD8T-14F530-AB: ERR
(ERR) [23:17:00.007] Downloading JD8T-14F535-AB: ERR
(OK) [23:17:12.136] Service procedure completed successfully.
(OK) [23:17:41.177] PCM Module firmware update has been started
(WARN) [23:17:41.188] Reading vehicle info...
(WARN) [23:17:49.261] Downloading firmware files from the Internet...
(ERR) [23:17:51.286] Downloading HN1A-14C273-CB: ERR
(ERR) [23:17:51.299] Downloading KD8G-14C204-CE: ERR
(OK) [23:17:56.473] Service procedure completed successfully.
(OK) [23:18:02.312] BCMii Module firmware update has been started
(WARN) [23:18:02.325] Reading vehicle info...
(WARN) [23:18:07.842] Downloading firmware files from the Internet...
(ERR) [23:18:09.869] Downloading HU5T-14C187-ACA: ERR
(ERR) [23:18:09.885] Downloading JU5T-14C184-ACJ: ERR
(ERR) [23:18:10.896] Downloading JD8T-14F389-ACC: ERR
(ERR) [23:18:11.908] Downloading JD8T-14F390-ACB: ERR
(ERR) [23:18:11.921] Downloading JD8T-14F391-ACC: ERR
(ERR) [23:18:12.936] Downloading JD8T-14G163-ACB: ERR
(ERR) [23:18:13.947] Downloading JD8T-14G570-BCB: ERR
(ERR) [23:18:13.959] Downloading JU5T-14G162-MCH: ERR
(ERR) [23:18:13.980] Downloading JD8T-14C636-ACE: ERR
(OK) [23:18:18.971] Service procedure completed successfully.
(OK) [23:14:17.151] BCMii PATS programming has been started
(WARN) [23:14:19.191] Checking PATS version...
(WARN) [23:14:20.561] Checking connection to FORScan server...
(WARN) [23:14:21.536] Checking adapter...
(ERR) [23:14:21.548] Service procedure has been interrupted
PATS and Firmware update issue
boosted_diesel
Re: PATS and Firmware update issue
Your screen shot shows it’s updated everything with the exception of pats.
It also shows that it failed at the exact second it began checking the adaptor. Are you sure your adaptor is ok and suitable for the task?
