Ford RANGER 2.5 TDI 2010
Sergey Malyshev
- Vehicle: Ranger,TDI 2,5/105 kW, 2010
help with forscan. INSTALL FORScan + extended license, connected the vLinker FS scanner + driver installation. I connect it to the car, but the scanner does not show all the blocks. I want to turn off the "Scandinavian light" (when the ignition is on, the dipped beam and dimensions are turned on). What to do? Please help
