So I had tried to replace my lead frame and when I did it was still not working. So I checked to see if the PCM or TCM had updates. I updated to AU7A-12A650-LLC. Now I have a couple codes I am unable to clear. I had to use IDS to program as FORScan failed on loading block 2. Also seeing 2 ABS codes. Appreciate any help
PCM codes: P0010,P0020,P0102,P0443,P0602
ABS codes: B1596,U0401
Help! Unable to get truck programmed.
CDEROBERTO
- Vehicle: 2010 Ford F150 Lariat Crew Cab 5.4L 3V, 6R80, 4x4
