Are there release notes for this release?
I may have found an issue.
A long time ago I purchased a lifetime extended licence. Might have been in 2020 . .
I recently upgraded to v2.3.70 release and re-installed the licence using the provided key.
I needed to look at configuring a new ABS modulator.
The licence shows as “Extended license. So this is good.
The vehicle is a 2016 Ford Territory Diesel (Australian model not the Chinese version).
But when I go and look at the ABS options under coding I only see “ABS Module initialisation/relearn from Central Configuration” and I do NOT see “ABS configuration (AS BUILT format)".
This option “ABS configuration (AS BUILT format)" used to be available. I could downgrade the version I am running and re-check but thought to ask before I do this.
Was this AS BUILT option dropped in v2.3.70?
Other "AS BUILT format)" options are available.
Release 2.3.70 release notes?
Toiler
- Vehicle: Territory (AUS), Diesel, 2.7ltr/144kw 2016
Re: Release 2.3.70 release notes?
I found the release notes. Apologies.
Also that function I am seeking may not have ever been available for the Territory???
