Hi everyone,
I recently replaced the steering rack on my 2019 Mustang with a newer unit from a 2020+ model. I’m running into some frustrating coding issues with FORScan that I hope the experts here can help me untangle.
Old Rack (Original 2019):
Part Number: JR3C-3F964-AF
Strategy: JR3C-14D003-AA
Calibration: JR3C-14D004-BD
New Rack (Installed 2020+):
Part Number: LR3C-3F964-AC
Strategy: LR3C-14D00x (2020 series)
The Issues:
1. As-Built Persistence (Auto-reverting codes):
Every time I try to write the GT or GT350 parameters, the PSCM seems to "auto-correct" or reject the values.
If I write 0201 in 730-01-01 (GT), it automatically reverts to 0200 after a reset.
If I write 0601 or 0301 in 730-01-02 (Tuning ID), it consistently reverts back to 0001 (Base/Rental tuning).
It feels like the LR3C firmware has a hard-coded integrity check against my 2019 VIN.
2. Steering Mode Offset (Mapping Shift):
The only way I can get the toggle switches to work is by using 0100 in the second block of 730-01-01. However, the modes are completely offset when looking at the PIDs:
Physical switch on Comfort -> PID STEER_FEEL reads Sport.
Physical switch on Normal -> PID STEER_FEEL reads Comfort.
Physical switch on Sport -> PID STEER_FEEL reads Not Used.
3. Missing "Module Configuration" Menu in FORScan:
In FORScan, I only see PSCM Module Configuration (As-Built Format). The "friendly" text-based PSCM Module Configuration menu is completely missing.
Because of this, I don’t have a way to run the Central Configuration Learn or any calibration procedures other than the basic reset.
My Questions:
Is it normal for the "friendly" Module Configuration menu to be missing when swapping an LR3C rack into a 2019 car?
Is the LR3C strategy simply incompatible with the 2019 CAN-bus signals for steering modes?
Do I need to perform a firmware "downgrade" (Strategy flash) to a JR3C version to make this rack behave like a 2019 unit?
I’ve tried writing with a battery charger connected (maintaining 12.6V+), but the results are the same. Any insight into how to get the GT350 tuning to "stick" on this 2020 rack would be greatly appreciated.
Thanks in advance!
PSCM Swap (2019 to 2020 Rack) - As-Built Reverting and Steering Mode Offset Issues
v8stangram
- Vehicle: mustang gt v8 2019
