BMC module missing
Lab70
BMC module missing
Post by Lab70 »
you have idea why the BMC module is not detected by Forscan on a Ford Focus MK3?
I use an interface ELM327 USB HS/MS CAN. All other module are correctly detected.
Re: BMC module missing
If you mean Body Control Module, on Focus 3 it is named BCMii and should be available on HSCAN bus. If it is not detected, most likely it is some problem in FORScan or adapter, in this case we recommend to contact our support by email (and attach internal FORScan logs as instructed on Contact Us page).
If you mean some other module, please clarify, because the BMC abbreviation is not clear.
