Writing to IPC of newer F-series trucks, How???
johnpsz
Vehicle: 2017 Ford F-450
Post by johnpsz »
I have seen a few times in older versions that writing to the IPC would hang and never complete, it looks like writing support to this module was taken out of the last few releases. Is there a plan or does any know if/how to write to the IPC module? I am looking to write to my 2017 Super Duty, but I understand that most changes cascade and the other F-series trucks cannot write to the IPC either.
johnpsz
Re: Writing to IPC of newer F-series trucks, How???
Post by johnpsz »
I see no updates on this forum, but I have heard on the vehicle specific forums that there were emails from FORScan between a few members mentioning that writing to the IDC is only an issue with the newer 8' Higher trim level dash. Also, they have already been addressing this and it should be available in the next version release. Can FORScan please confirm this?
The problem is finally solved, test version was sent today to few trucks owners and they confirmed it works, so it will be included in 2.3.10 official release. If you need this function urgently, please request test build from support (send PM to FORScan user on the forum).
johnpsz
Post by johnpsz »
Thank you soo much for your efforts.
