Hi guys,
Finally i have upgraded my Sync 2 to Sync 3, not very complicate, worth to try DIY. And so far 99% of features doing fine and not even single is still missing for my 15 Focus ST2.
IMO, the hardest part for me is to reprogram the APIM by Forscan. Too many suggested code on internet, it really takes time to prefect fit your car. Some of them were working fine but some of them have conflict with others! But I still have 1 single problem waiting to solve!
As you can see below.
The left and right zone temperature on sync 3 are swapped!!! And the funniest part is the touch buttons for adjusting the temp are totally correct!!
For example,
1) I turned the physical knob to 17'C for Right Zone and the LED near the physical for Right Zone adjusted to 17'C accordingly, but the Sync 3 display for the Left zone followed and Right zone remain no change.
2) I adjusted the Right Zone to 18'C by using the sync 3 touch buttons and the LED near the physical knob for right Zone was correctly follow. But the Sync3 for right zone remain no change and the left zone changed to 18'C.
Sync 2 to Sync 3 problem! Left/Right Zone Swapped
- IMG_8536.JPG (75.71 KiB) Viewed 7673 times
Re: Sync 2 to Sync 3 problem! Left/Right Zone Swapped
Possibly a left hand drive/right hand drive coding issue?
Use this vin
2FMPK4K87GBC27130
to download APIM Configuration for Your car from
https://www.motorcraftservice.com/AsBuilt
2FMPK4K87GBC27130
thanks for share
Did you sort this problem ?
