Mazda3 Y6 2003-2008 new service functions
donate
Vehicle: Mazda 3 1.6 CRTD Y6 DPF 109 HP, 2007
Post by donate »
Hi, to diagnose a fault in my DPF system, i should need "Reset Differential Pressure Sensor Learned Values" for my model, as i am going to change it temporaly to examine data and see if it is faulty. I don´t know if it is possible, and if you have plans to include in future versions.
Thanks.
Re: Mazda3 Y6 2003-2008 new service functions
This type of PCM (used with Mazda Y6 engines, as well as with Ford DV6 engines) has no DPS reset function. Only DPF learned data reset is available (it is implemented and should be displayed in Service section when you connect to your Mazda).
donate
Post by donate »
Yes, it´s available, but as i understood, it´s only when DPF is replaced.
Thanks for the info.
