2015 f250 Lariat codes not there
rogerclyne
- Vehicle: Ford, 6.7L Diesel F250, 2015
I have everything all hooked up and connects fine. Going to change temp display and dpf% screens for example but when I open the IPC module I don't see the number set or edit for temperature for example? Help
rogerclyne
Re: 2015 f250 Lariat codes not there
Anybody?
rogerclyne
To elaborate:
Looking for some FORScan assistance on a 2015 6.7L Lariat. I got everything all hooked up with https://www.amazon.com/gp/product/B006N ... UTF8&psc=1
and FORScan all installed. It sees the truck and connects, loads, etc. Problem is when I go into IPC As Built or IPC (no As Built Tag) module for example to activate Temperature display for example, the 720-07-01 code set is not listed to edit? I have others there but not this one? Same this when I try to activate the DPF% screen, I open IPC module and 720-07-02 is not there for me to edit? Any assistance appreciated.
