2017 F150 double horn honk with aftermarket remote star
Looking to disable the double horn honk on a 2017 F150 when remote starting. Remote start is a preprogrammed plug and play. All factory options work with start up, but trying to eliminate the honk for early morning starts.
Re: 2017 F150 double horn honk with aftermarket remote star
Did you tried this one?
Double Horn Honk disable BCM 726-41-02 xxx0 xxxx xxxx
12voltWILL
- Vehicle: F150, 5.0L v8/285HP, 2015
Is the aftermarket R/S made by Idatalink or Flashlogic by chance? If so you are probably having to press lock 3X to start it. The module can be reprogrammed to lock unlock lock and this will prevent the horn from honking.
Thanks for the reply 12voltWILL, would you know if there are instructions to reprogram the module for the lock, unlock, lock, start.
Thanks again
Thanks again
the-drew
- Vehicle: 2017 f150 2014 transit connect 2012 transit conn
you will need a programmer and an account with one of the idatalink sites or fortin depending on the brand that you have installed. idatalink.com fortin.ca
