hello
i bay a ford focus 1.6 tdci from 2006 hands free version, but the last owner have changed ecu + ic and ignition switch from a 2008 version.
New IC is orange lcd and orguinal is litel green lcd version, on the moment IC give me esp and abs error and also software incompatible with abs.
the big problem is that when i close the car the dash not swutch off and car batterie goes off in 2-3 houers, and also remote is also not work.
is it possible to reprogram the abs do that comonicate with the abs?
thanks
jp.
ford focus incompatible software with IC and ABS
Re: ford focus incompatible software with IC and ABS
Problem Solved
Change only on Bit in "2" on 720.01.01 ***2
