I've a question for people who know how works the EGR ! I've a Mazda 3 1.6 MZ-CD with 99 950km and there is 2 000km i've changed my DPF because he was full. But i'm still getting a problem with it.
I've a DTC P2458 "DPF duration..."
1) For me the DPF have been replaced with a new one now there is 2 000km
2) The DPF pressure looks good like 0.1-0.2 kPa in idle, and 3kPa max at 3000tr/s ! Is good for you ?
3) I've clean the EGR yesterday but i don't know if the values looks good, someone can give me the best values ?
4) All the pipes, intercooler, ... are clean !
5) No Pressure Sensor problem (or no DTC in Forscan?), hoses have been cleaned, no hole or tear
6) The DPF Additive (Eolys 176) have been refill and reset procedure with Forscan (OK)
7) I've reset DPF and EGR with Forscan
After thoses procedures, i'm still having the P2458 after than the car try to regen ! It's so borring.. Before i was to 4.7l/100km now more than 6l/100km ! And DPF regen often ! (like every 50/70km..
This is my Forscan result with the EGR, are they good for you ? Wha's are EGR_PCT , EGR_TV, EGRVR, EGRVP ? Because like i read on internet, the EGR must be closed but how to know if she's closed ?
1) Car on, not running :
2) Car idle (~757RPM) :
3) Car driving (115km/h on highway - 110km/h limited
4) After drive like 32km .. (idle, not driving) :
EDIT :
Yesterday, after drive few kilometers the DPF try to regen. The DIST_REGEN stop to 148km if a normal regeneration is ~10-12km values with DPF are between 137km-148km (DIST-REGEN)
1) Just before regen, pressure increase but nothing special :
2) DPF start to regen (?) :
3) DPF is regen, DPF temps is 562° , EGR is closed ? (EGRVP) :
I don't really understand if it's good. Before regen the DPF pressure goes high but during regen DPF pressure looks normal ? Is the EGR closed when DPF is running (EGRVP) ?
The DPF is new (Walker DPF) i paid it 450€
In Forscan, there is no option to reset DPF Pressure sensor learn value, there is no way to reset this if i'll buy a new one ?
If someone have an idea, because this problem is here since 3 months and i'm going to be crazy ! Sometimes i'm thinking to burn this car !
