I had problems with backup camera, coming on then going black. It also reversed picture and had the backup guidelines missing. It would not allow me to turned them on.
I used FORScan 12.3.8 version and calibrated camera then deleted code logs and recalibrated rear camera.
It worked perfectly, guidelines back no more flicking on off or going to black screen.
Used Obdlink Mx Bluetooth and FORScan ver: 12.3.8
FORScan excellent product, hope this helps others with similar problems.
F150 Backup Camera
Scorpiao58
- Vehicle: F150,V6/3.5,2011
Re: F150 Backup Camera
Wondering if you could help me out, I installed a backup camera into my 17 f150 xl, all ford parts. I used forscan and changed the code to enable the camera but there is no guidelines and the zoom doesnt work. Is it part of the coding to get these to work and if so do you happen to know what the coding is?
Thanks in advance
Thanks in advance
Scorpiao58
Have you tried recalibration of camera on bdycm module using forscan
