[SOLVED] Can´t execute new 2.2.0 version
carlus
Vehicle: MAZDA CX7 MZR CD 2.2 2010
Post by carlus »
I install a new version but when i try to run, i can´t. A problem ocurr.
SO: Windows 7 64 bits.
The program install correctly but when i execute it, apperas this windows:
More information?
Thanxs.
MAZDA cx7 diesel
carlus
Re: Can´t execute new 2.2.0 version (problem)
Post by carlus »
More information.
I just installed the version 2.1.24 and it works perfectly.
MAZDA cx7 diesel
We will investigate this problem as soon as possible.
carlus
Post by carlus »
FORScan wrote:We will investigate this problem as soon as possible.
OK, I just found a solution to it, until the team forscan the solvent with a new version.
If we have installed a previous version of forscan program and have connected the program with our car, we must manually delete the temporary directory forscan application before installing the new version 2.2.0. In my case, this temporary directory is: c:\users\username\AppData\Roaming\FORScan
A greeting.
MAZDA cx7 diesel
Holger
Post by Holger »
Hello Carlus,
I ran into the same error after installing the new version.
Thank you for your information, it solved my problem too :-)
In my case it was only necessary to delete the file settings.ini.
Greetings
Holger
Re: [SOLVED] Can´t execute new 2.2.0 version
We have released version 2.2.1 that should have this problem fixed.
