im new to forums so please tolerate me!
ive been trying some of the 2018 expy changes and 1 thing i found is that some work with engine running and others in acc mode
working so far: bambi,remove splash screen,Lincoln black label background,nav in motion,removal auto start/stop,seat controls on touch!
Does anyone know the AS Built in data for a ford fusion 2015 titanium. My automatic climate control is on my sync 2 screen but when I press the button, nothing happens. I want to reset the APIM module but I do not have the codes to do so. PLEASE HELP
2013 Platinum is my truck. I am trying to make changes in my IPC as built. For some reason I can only see 3 rows of data. Most all spreadsheets have many more for all year trucks but I dont seem to have it? I have switch in my ODB with HS/MS. Both work and I seem to be getting everything for all other modules.
Any help or guidance appreciated.
I want to disable the seat belt minder on my 2013 and also want to stop the singing sound when door is open with keys in ignition.
This is kind of a no-brainer, but I had to learn it the hard way. If you replace a module on your car from a wrecker, you need to load the as-built programming into that module for your VIN. I bought a Texas flooded 2017 Fusion that had 586 miles on it. I've replaced many modules including the Shift Control Module, ACIM, ACM, BECMB, and others. When I installed them they seemed to work, but I'm realizing that some of the weird things that are going on is because of the wrong code. Forscan is priceless!
Thanks.
FORScan wrote: Fri Jun 23, 2017 11:28 am
Here are some very helpful resources created by enthusiasts:
1. Tutorials:
Great FORScan tutorial created by Livnitup from F-150 forum. It was developed for F-150, but the principle of work with As Built data can be applied to any model.
