Hello everyone
I'd like to tell you that I am very grateful foescan forum and everyone who participates in it.
I changed everything I wanted on my Ford Mondeo using forscan diagnostics. but I also got two dtc code
Hcm b1087:00-c8
Hcm b1088:00_c8
I did not change and did not touch anything in the hcm module,but I made changes to the bcm and ipc module.
I also noticed that the frontled headlights do not work properly, in the middle No light.
Please Help.
Ford mondeo 2015 code HCM1087 HCM1088
Re: Ford mondeo 2015 code HCM1087 HCM1088
I finally solved the problem,
For someone who needs help, just write
Be nice to know what you did?
hello to you
So I did it like this.
Firstly. Turn on the car's contact and leave the headlights on.
Secondly connect with Forscan Diagnostics and delete all errors. (Do not turn off the headlights)
Third. Check in dtc Is there any more errors? if they still exist enter the bcm module and deactivate corner fox light and DLR PARKLAMPS WITH ....... After that repeats the second and third step. this should erase errors.
(but it's very important not to turn off the headlights)
Fourth. reset modules (BCMii AND PSCM)
Fifth. turn off the diagnostics and turn off the battery (plus) In my case 12 hours.(After this, place the headlights on the automatic).
when you turn on the battery Drive for about 20 minutes,
After that, stop, turn off the engine, when you turn on the engine it should be all right. (When you turn on the battery at the beginning, you will not get results)
everything will be fine when you turn off and restart the car after the first ride.
This problem struck me for more than two months and finally I solved it.
I hope to help you if you have other questions, just choose .... All the best....
I forgot module HCM You have to reset it together with BCMII PSCM
I have a similar problem. I added HCM module, DynamicLED headlights and installation from mondeo mk5 and I have these two errors, and for this I need to calibrate the system. Forscan doesn't have the right tool. I will reset the modules with UCDS but how to start calibration - adaptation of lights?
Whatever you do, when you turn off the lights manually then this error occurs again.
As long as you keep the lights on automatically then there will be no problem
Thanks You.
Fordsejaca
- Vehicle: Ford Mondeo, 2.0TDCI 180CV, 2017
Hello Igor,
It happened to me the same as you. When I tried to add the DRL checkbox in the settings menu (IPC module 720-02-02, changing xxEx xxxx xxxx) I got this error. And I get it always I turn off the lights. If I have the lights in auto everything is ok. But, I don't see any change when I enable or disable the DRL checkbox in the settings menu. Did you keep the setting appearing in the screen or you disabled it? In case you enabled it, did you see any change?
I will try to do your method, but I want to know first if you disabled the option or not. Thank you very much.
